Will new "Process Model" in "Conformance" change the initial view of "process explorer" in analyses
Hi All,
Could you please clarify the below query!
Will new “Process Model” in “Conformance” change the initial view of “process explorer” in analyses?
We have a requirement to change the initial view of process explorer with a certain list of activities given by the user. And the further expansion of the activity list should show the remaining activities.
Thank you.
No, the process model in conformance checker is there to build an ideal process flow and compare it to the actual as is process. This comparison is automatically done within the conformance checker using the defined process model.
For this you would need create and add activities to the activities table using SQL transformations.
In general, I would recommend you to do our online trainings as they cover all of the mentioned steps (in case you have access to them).
Viana
