Scatter Plot | Visualizing more than 2 KPIs
Hi Team,
We want to visualize three KPIs corresponding to a particular dimension. We are thinking of achieving this in terms of the horizontal and vertical axis of a scatter plot (2 KPIs) and the third being the bubble size.
I wanted to know whether there is a way to increase the size of the bubbles based on additional KPI in Scatter plot (other than the ones specified in horizontal and vertical data series) ? If not, is there a way to look at additional KPIs in scatter plot when you hover over the bubbles ?
Thanks in Advance
Soham Potdar
According to the (CPM 4.5) docs on the bubble chart you can use 1 dimension, and 2 KPI’s, where the second is used for size. Downside is that both KPI’s need to be numeric. For me categorical and date/time types did not work.
Hi joosbuijs,
Thank you for your response. However, I want to analyze 3 KPIs against one dimension.
Would this be possible in scatter plot or bubble chart ?
Thanks in Advance
Soham Potdar
Hey jossbuijs, Thank you for your response. However I want to add a third KPI. Is this feasible in bubble chart or scatter plot?
