Save overview in .pgn format
I can’t save overview in .pgn format.
option does not appear:
Export:
BPMN export (XML) and
export component (PGN)
Hi Henrique,
Have you check the Analysis settings.
In General Settings → Allow bpmn export of the process explorer need to be ON.
Thanks!!
Pooja
thanks for listening. I use the free version. I can’t find this option in the Process Explorer.
Hi Henrique,
Are you trying in Celonis Snap?
Thanks!!
Pooja
