Pycelonis get_data_frame method failed when column name is like "#{VBAP.PSTYV}"
Dear Celonis development team,
I tried to connect and extract data from IBC to my Colaboratory python environment using Pyceonis.
Normally it worked correctly with below scripts.
login = {“celonis_url”: my_url, “api_token”: my_token}
celonis = get_celonis(**login)
analysis = celonis.analyses.find('id of my analysis)
sheet = analysis.published.sheets.find(‘id of my sheet’)
component = sheet.components.find(‘id of my component’)
df = component.get_data_frame()
But sometimes get_data_frame method returned exception.
Exception Traceback (most recent call last)
in ()
----> 1 df = component.get_data_frame()
2 df
2 frames
/usr/local/lib/python3.6/dist-packages/pycelonis/objects_base.py in get_data_file(self, pql_query, file_path, export_type, variables)
647
648 if r[“exportStatus”] != “DONE”:
–> 649 raise Exception(f"Export failed. Status: {r} \n\n Query: {pql_query}")
650 else:
651 file_type = export_type.lower() if export_type != “EXCEL” else “xlsx”
Exception: Export failed. Status: {‘id’: ‘08da3644-661e-419f-8a6d-b683b03a2a04’, ‘exportStatus’: ‘FAILED’, ‘created’: 1571061484375, ‘message’: ‘The provided query does not contain a valid table statement to be exported.’, ‘exportType’: ‘PARQUET’}
Query: [‘TABLE( VBAP.PSTYV||’ - ‘||VBAP.PSTYV_TEXT AS “#{VBAP.PSTYV}”, VBAP.PSTYV||’ - ‘||VBAP.PSTYV_TEXT AS “#{VBAP.PSTYV}”, “KNA1”.“KUNNR” AS “#{“KNA1”.“KUNNR”}”, COUNT_TABLE(“VBAP”) AS “#SO Item” FORMAT “,f”, AVG(CALC_THROUGHPUT(ALL_OCCURRENCE[‘Process Start’] TO ALL_OCCURRENCE[‘Process End’], REMAP_TIMESTAMPS("_CEL_O2C_ACTIVITIES".“EVENTTIME”, DAYS))) AS “Throughput Time (Days)” FORMAT “,f”, SUM(“VBAP”.“NETWR_CONVERTED”) AS “Net Value (JPY)” FORMAT “,f”, AVG(PU_AVG (VBAP, CASE WHEN ISNULL("_CEL_O2C_ACTIVITIES".“USER_TYPE”) = 1 \r\n THEN NULL \r\n WHEN ("_CEL_O2C_ACTIVITIES".“USER_TYPE” = ‘B’) \r\n THEN 1.0 \r\n ELSE 0.0 \r\n END)) AS “Automation Rate” FORMAT “.2%” ) ORDER BY SUM(“VBAP”.“NETWR_CONVERTED”) DESC NOLIMIT;’]
I changed column name from “#{VBAP.PSTYV}” to simply “Item category” then it worked, so there is something defect in parsing column name. Could you check program ?
Kazuhiko
Hi Kazuhiko,
Which version of pycelonis are you using? You can check this in pip list or by using
from pycelonis import __version__
print(__version__)
Simon Riezebos
Dear Simon,
My Pycelonis version is 1.1.6.
Kazuhiko
Hi Kazuhiko,
When I try to reproduce this for me the #{} are always removed from the column names. In the future it will be possible to choose whether you want to use the raw names or the names with name mapping, which should make your current error impossible :slight_smile:
For now I guess changing the name is the best option.
Simon
Dear Simon,
Thanks for your checking. Please let me double check whether your pycelonis version is later than 1.1.6.
Best regards
Kazuhiko
#{} is not parsed in the current version 1.1.9.
I misunderstood Simon’s comment. I will change column name in my analysis.
Hi Kazuhiko,
It is parsed in most cases, but in some cases the column data is not fully consistent. When #{} is used and the datamodel has name mapping enabled it usually works. We are working on a solution that covers 100% of the cases.
Simon
