Process explorer sorting the activities
We have several activities which have the same sorting and same event time. Is there a possibility to change the sorting of the activities in Process Explorer in the front end Celonis ?
Best regards
Adam
Hi Adam,
As far as I know this is not possible in the front-end, but there is an additional sorting column which can be provided in the datamodel to sort activities by if the timestamps are equal.
Hope this helps!
