PQL Function GLOBAL
How is the syntax of this function? Does it work together with all other aggregations?
I get the error ‘GLOBAL function may only be used in conjunction with aggregates’.
My formula is quite simple: GLOBAL(COUNT_TABLE(“some table”))
Cheers!
#2
I used it for comparing TPT’s to global average in a following way:
AVG( CALC_THROUGHPUT(...) )
GLOBAL( AVG( CALC_THROUGHPUT(...) ) )
