Managed Authorization in AR Process about BSEG.BUKRS
Hello Community,
i implemented an authorization category for users in our AR-Process for the SAP field BUKRS. The authorization group works very well for each analysis. Anyway only for the Analysis “Cash Discount” the authorization Group isn’t working. Has anybody an idea why this happened only for this Analysis?
Is it possible that there is an association with the “Load Script”?
(CLEAR SELECTIONS; SELECT “BSEG”.“ZBD1P” AS “Cash Discount Percentage” > 0;)
Thank you in advance!
#5
Hello Thomas,
there are several possible issues, however the filter does not seem to be a problem necessarily. In case you still look for a solution to this, it might make sense to send a message to servicedesk@celonis.com with screenshots attached so we can understand this issue better.
Henry
