KPI with Case When but non-mutually-excluding conditions
Hi everyone,
I need a KPI in a form:
if X then A
if Y then B
if (X or Y) then (A+B)
else null end;
As I want to use it in an olap as dimention (first column) where the other KPIs deliver values for A,B and A+B, it is is not the optimal solution to split it into two tables (looks not good).
It seems for me, it is not possible to use CASE WHEN as it uses ELSE after the first condition and automatically excludes the A+B.
Do you know if there is a solution?
Maria
Hi DrWindy, You can apply multiple conditions with CASE WHEN. It’s not clear to me why you would have A for X and B for Y while also requiring A+B if either X or Y? Shouldn’t this be a separate KPI? You can include both KPIs in the same OLAP table. Example:
CASE
WHEN X THEN A
WHEN Y THEN B
CASE WHEN X OR Y THEN A+B END
Well, I want to see how many activities A,B and A+B were performed in different departments.
And as I want it in one OLAP :
Activity___ Dept1___ Dept2 ___Dept3
A ____ | _______| ________| _______|
B ____ | _______| ________| _______|
A + B _ | _______| ________| _______|
If i apply 2 KPIs I am getting two columns for that and this is not what I want.
Maria
Do you mean that you want to show for each Department how often Activity A and Activity B took place? And also show how often either Activity A or B took place? Would that not be a case count on Activity A and B (if X then A, if Y then B), where the total row of the OLAP table would reflect A+B?
