How to get the Aggregation (Sum) of 2 single KPI components
How to calculate the sum of 2 single KPI components which are using the same function to provide the result but with different filters, and the filters are also using different tables to get the filters.
Hi Pritam,
you cannot combine the result of (visual) elements per se. What you can do is to replace the filter statements by including their logic in your actual KPI formulas. That way, you can combine these two formulas in order to calculate the sum.
If you need help with rewriting the filter statements, feel free to post them here.
Your Data Science Team
