How to find Object ID of analysis
Hello ML Experts,
Am not able to find the Object Id ? Can you please explain the way to find ?
Tried below option : No Luck !
Objects in celonis can be found using their ID or (substring of) name. Press shift-tab inside the parentheses to see the signature and documentation of each function.
How to fetch below Data ?
{‘permissions’: [‘MOVE_TO’,
‘DELETE_WORKSPACE’,
‘CREATE_WORKSPACE’,
‘DELETE_ALL_WORKSPACES’,
‘DELETE_ALL_ANALYSES’,
‘EDIT_ALL_ANALYSES’,
‘EDIT_ALL_WORKSPACES’,
‘USE_ALL_ANALYSES’,
‘CREATE_ANALYSES’,
‘DELETE_ANALYSIS’,
‘EDIT_WORKSPACE’,
‘MANAGE_PERMISSIONS’,
‘EXPORT_CONTENT’,
‘USE_ANALYSIS’,
‘EDIT_ANALYSIS’],
‘id’: ‘117f7528-8504-4450-9fd6-8ebcf1749d18’,
‘tenantId’: None,
‘name’: ‘OTD Prediction Binary - Technical App (OAF) - Copy’,
‘description’: None,
‘deleted’: False,
‘transportId’: None,
‘lastPublishedDraftId’: ‘7f82df02-b728-4ca3-acdf-1940dd7de7b0’,
‘autoSaveId’: ‘2e47dccc-8cbf-400d-8404-72e1f5298d0d’,
‘processId’: ‘acb6313c-bba8-46fd-9637-24c7d5463746’,
‘createDate’: 1556264369787,
‘favourite’: False,
‘contentId’: None,
‘contentVersion’: 0,
‘tags’: [{‘name’: ‘WillBeDeleted’}],
‘applicationId’: ‘’,
‘publicLink’: False,
‘lastPublishedDate’: 1564498481791,
‘lastPublishedUser’: ‘Simon’,
‘objectId’: ‘117f7528-8504-4450-9fd6-8ebcf1749d18’,
‘publishedDraftId’: ‘7f82df02-b728-4ca3-acdf-1940dd7de7b0’,
‘folderId’: ‘117f7528-8504-4450-9fd6-8ebcf1749d18’,
‘parentObjectId’: ‘acb6313c-bba8-46fd-9637-24c7d5463746’}
