Global Variable
Hello Celonis Team,
Today I am using a variable that is defined within an analysis.
How can I define the variable at the Data Model level so that we can use the variable throughout all the analysis that is created using that Data Model?
Regards,
Sachin
#2
Hello Sachin,
unfortunately, there is currently no option to create a global variable in celonis as you explained. You would need to copy the variable in the other analysis as well. The community has also the section “feature proposals” where you can post this function as a feature request.
Viana
#3
Sounds similar to the central variable repository post that Hans proposed back in October. https://community.celonis.com/t/central-repository-of-all-variables-and-saved-formulas-per-data-model/716
