Formula with two conditions
hello, i need your help with a formula.
The following formula does not yet work 100%.
COUNT (DISTINCT CASE
WHEN “/RWEE/PMCP_TAUFK”.“SLATX” LIKE ‘S -% - S%’ THEN “T_CEL_AT_HP5”. “AUFNR1”
WHEN MATCH_ACTIVITIES (“T_CEL_AT_HP5”. “TXT30”, NODE [‘Outlook: finished message sent’]) = 1 THEN “T_CEL_AT_HP5”. “AUFNR1”
ELSE NULL END)
In my opinion it does not matter in this formula which of the two conditions applies.
I would like to have the formula changed so that both conditions must be met.
What needs to be changed in the formula?
thx
Hi Steven,
in a CASE WHEN, the first condition that is true is taken and the corresponding value in the THEN is returned.
If you have multiple conditions that should be true, you can simply connect them with an AND. In your case, it would look like this:
WHEN "/RWEE/PMCP_TAUFK"."SLATX" LIKE 'S -% - S%'
AND MATCH_ACTIVITIES ("T_CEL_AT_HP5". "TXT30", NODE ['Outlook: finished message sent']) = 1
THEN "T_CEL_AT_HP5"."AUFNR1"
ELSE NULL END)
Cheers
David
MERCI. it works very nice :slight_smile:
