Filtering FTR analysis to only cases with "Clear Invoice" activity
Hello team,
We recently began implementing a First Time Right analysis for SAP ECC using the most recent template from the App Store. One item we noticed was that the KPIs included in the analysis all filtered to only cases that included the “Clear Invoice” activity:
Affected Net Order Value:
SUM(CASE
WHEN PU_COUNT(“VBAP”, “CEL_O2C_ACTIVITIES"."ACTIVITY<%= language %>”,“CEL_O2C_ACTIVITIES"."ACTIVITY<%= language %>” = ‘<%= clear_invoice_activity %>’ ) = 0
THEN NULL
WHEN PU_COUNT(“VBAP”, “CEL_O2C_ACTIVITIES"."ACTIVITY<%= language %>” ) - PU_COUNT_DISTINCT(“VBAP”,“CEL_O2C_ACTIVITIES"."ACTIVITY<%= language %>” ) = 0
AND PU_COUNT(“VBAP”, “CEL_O2C_ACTIVITIES"."ACTIVITY<%= language %>”,“CEL_O2C_ACTIVITIES"."ACTIVITY<%= language %>” IN (<%=rework_activities%>) ) = 0
THEN 0.0
ELSE “VBAP”.“NETWR_CONVERTED”
END)
FTR Ratio:
AVG(CASE
THEN NULL
THEN 1.0
ELSE 0.0
END)*100.0
I’d like to understand what the concerns would be with removing this statement and considering all cases instead. I ask in part because we are having a problem with the Clear Invoice activity pulling in consistently, but also because we would want to include items that never go through that activity (such as cancelled orders).
Can you help me understand why the “Clear Invoice” filtering logic was included on the First Time Right analysis provided by Celonis?
Thank you!
Hi Alex,
the Clear Invoice filtering was added because a desired process would ideally contain a “Clear Invoice” activity.
Whether or not removing the activity totally depends on how you define the FTR Rate from business perspective. In case you would like to remove it, you could just remove the first PU function
PU_COUNT(“VBAP”, “ *CEL_O2C_ACTIVITIES"."ACTIVITY* <%= language %>”,“ *CEL_O2C_ACTIVITIES"."ACTIVITY* <%= language %>” = ‘<%= clear_invoice_activity %>’ ) = 0
Using the same logic, you could also exclude certain activities using WHEN PU_COUNT(“VBAP”, “ *CEL_O2C_ACTIVITIES"."ACTIVITY* <%= language %>”,“ *CEL_O2C_ACTIVITIES"."ACTIVITY* <%= language %>” IN (<%=excludedActivities%>)) = 0 THEN NULL
Viana
