Differense between two dates
Hello. I have a planned processing date for the order “CASES_SHOP”. “DATENORM”, and an actual processing date for “CASES_SHOP”. “DATEPOST”.
“CASES_SHOP”. “DATENORM” - 20190929
“CASES_SHOP”. “DATEPOST” - 20200830
DAYS_BETWEEN ( “CASES_SHOP”.“DATEPOST” , “CASES_SHOP”.“DATENORM”) - it doesn’t work.
Please tell me how can I calculate the difference between them?
Hi @Radamir96,
are these to columns “CASES_SHOP”. “DATENORM” and “CASES_SHOP”. “DATEPOST” defined as timestamps? I assume they are defined as STRINGS.
In case they, you have to use the function TO_TIMESTAMP to transform your STRINGS into timestamps.
Justin
It’s all right!
Thank you very much!
