Deviding KPI1 / KPI2 does not work. Why?
Hello everybody,
I have a problem, which is definitely easy to solve, but I lack the idea.
I have a KPI 1:
COUNT (DISTINCT CASE WHEN “EBAN”. “LOEKZ” = ‘X’ THEN “EBAN”. “BANFN” ELSE NULL END)
I have a KPI 2:
COUNT (DISTINCT CASE WHEN MATCH_ACTIVITIES (NODE [‘Technical Clarification’]) = 1 THEN “EBAN”. “BANFN” ELSE NULL END)
I would like to divide KPI 2 / KPI 1 in a new KPI 3.
The new formula…
unfortunately does not work that way.
Can anyone help why?
Thanks a lot
What does not work? Do you get an exception? Or an unexpected result? Or??? I would need a bit more information to help you out.
Sry, we speak from an wrong result, not an error.
#technical-implementation
I hope this picture helps.
Hi Steven,
First of all I would set the formatting not to .10% but to decimal.
Second, I believe 10268 / 78 = 131.64
Please let me know if this fixes stuff.
I’m sorry.
yesterday was not my day.
I mean of course KPI 2 : KP1, so 78 : 10.268
But the formula order is correct.
With the .10% I just wanted to make it clear that my result is 0.
0 as a result is wrong.
Sorry for beeing persistent but could you change the formatting to decimal?
I find that incorrect formatting strings might mess up the output. Once we get the PQL working, you can tweak the formatting all you like :wink:
