Determine Error Location
When an error message appears, how can I determine the location of the error? Ie which component / loaded script is generating the error?
Hi kalanikayser,
Select the data job that fails and click then on the ‘Logs’ panel. Now click on the log with the status failed, and you see the following screen:
Here you can see which transformation leads to an error, and what the error is about. Unfortunately, the row numbers are not shown in the editor and in the error description, this would be a very nice addition!
