Custom process exporer KPI - connection
We try to place a different value in the process explorer. For the activity this works. Using the same formula (datediff) at the connection does throw an error after saving.
Is there any kind of sample available or tutorial or documentation.
THX
#3
Hi @kristin.nuessler,
can you provide an insight which formula you are using?
