Could not locate column
I am getting the error message “could not locate column in table” while reloading the data model. However, the column is in the view, I have checked if I am using the correct source table and if the columns are synchronized (all ok). What else could be the root cause of this error?
Thank you.
Lenka
Hi Lenka,
which Celonis Version are you using?
Viana
Hi Viana,
I am using 4.6.0 version.
Lenka
