Hi Team,
We have been using Conformance checker sheet in Celonis for testing conformance on our processes. When we perform the conformance check we usually use the crop selection filter on the top to limit our process to a certain set of activities(i.e. a part of the process) which we need to test on the basis of the process model. However, in certain scenarios, we need to also substitute this with a query in the load script which we are doing it using the below mentioned query:
FILTER
CASE
WHEN CALC_CROP (FIRST_OCCURRENCE [ ‘START_ACTIVITY’ ] TO FIRST_OCCURRENCE [‘END_ACTIVITY’],
CASE
WHEN “Activity_table”.“activity_column” = ‘A’
THEN ‘START_ACTIVITY’
WHEN “Activity_table”.“activity_column” = ‘B’
THEN ‘END_ACTIVITY’
ELSE “Activity_table”.“activity_column” END
) = 1
THEN ‘Crop’
ELSE NULL
= ‘Crop’;
The above query is working fine and we can see the cases getting filtered in all the components. However, if we deep-dive in some violation from the conformance sheet there is an issue with the analysis where we have the load script filters.
With Load script as cropping:
In this scenario when we deep dive for the violation and wish to see it in a variant explorer we are not able to see the variant explorer getting filtered on the basis of the selection (i.e. Let us suppose the violation is ‘Activity A is undesired’ and I wish to now view the cases in variant explorer for this violation, I see that the variants that are shown after applying filter on those violating cases do not represent that violation)
With the selection as cropping:
In this scenario the when we deep-dive for the violation and wish to view the cases in variant explorer the variant explorer gets filtered on the basis of selection and works fine
Also, we need to have the load script for the cropping since we have to apply multiple filters with logical conditions (i.e OR, AND etc.) which I believe will not be possible using the selection filters.
It would be of great help if anyone would help me with the issue. Please let me know if I am missing out on anything.
Regards,
Soham Potdar
