Cannot create first ML app in Training system
I’m trying to do the ML training, but I’m unable to create my first ML app. When I go to ML > Apps, it says “You haven’t created any apps yet”, which is correct, but then it shows me a button “Play Demo” instead of “Create App”.
I expected it to change after I had watched the demo video, but it didn’t. I don’t see a create button anywhere, so I am stuck. Please advise.
Thanks,
Maarten
Hi Maarten,
I am sorry that you are facing this issue. Can you share your team url with me? That will help me look into this issue and resolve it asap.
Noor
Hi Noor (Dutch, by any chance?)
Sure, my team URL is https://123mdv-gmail-com.training.celonis.cloud/process-mining/ui
Thanks,
Maarten
Hi Maarten,
Can you check now? You should be able to proceed now. Let me know if you still face any issues.
Noor
Hi Noor,
No difference. I still get “Play Demo” instead of “Create App”. Please advise.
-Maarten
Hi Maarten,
How about now? Hopefully it will work now. I manually adjusted the permissions.
Noor
Yep, now it works Noor, thanks!
-Maarten
