Cancellation Quote of Activities
Is there a way to calculate for each Activity (in an OLAP table) the cancellation quote, i.e.:
#Cases for which it was the last activity/ #Cases which flow through that activity in total
I already tried it with SOURCE and TARGET, but I couldn’t work it out…
#2
Hi Dirk,
the solution should be:
COUNT(DISTINCT CASE WHEN “ACTIVITY_NAME” = PU_LAST(CASES, “ACTIVITY_NAME”) THEN “CASE_ID” ELSE NULL END)
COUNT(DISTINCT “CASE_ID”
and “ACTIVITY_NAME” as dimension
#3
Hello Linda,
could you please check the formula as I got error message that table “ACTIVITY_NAME” is not found.
best regards
Christian
#5
Hi Cristian,
when using columns in a PQL formula, you need to include the table from which you take the column e.g. when using “ACTIVITY_EN” write “CASES”.“ACTIVITY_EN”.
The formula should be:
COUNT(DISTINCT CASE WHEN “_CEL_ACTIVITIES”.“ACTIVITY_EN” = PU_LAST("_CEL_CASES", “_CEL_ACTIVITIES”.“ACTIVITY_EN”)
THEN “_CEL_CASES”."_CASE_KEY" ELSE NULL END) * 1.0
/ COUNT(DISTINCT “_CEL_ACTIVITIES”."_CASE_KEY" ) * 1.0
Please replace “_CEL_ACTIVITIES” by the name of your activity table and “_CEL_CASES” by the name of your case table.
Kerstin
#6
Hello Kerstin,
thanks a lot, now it’s working but the results in the OLAP row could not be used as filter to find the cases in the detailled analysis. I assume that is because of the complex calculation that only the result is shown but use as filter is possible.
best regards
Christian
