Ariba-P2P Implementation
We are using Celonis 4.5 on premise and we have implemented ECC-O2C data model. To get further, we would like to implement ARIBA-P2P data model, but we don’t know which is the correct approach to extract the data to Hana.
Do you have some technical information about how to extract this data?
Thanks in advanced!
Diego
Hi Diego,
Did you try connecting ARIBA using standard connector provided by Celonis ?
Hi!
Unfortunately that connector is only available for IBC version, but not for the On Premise version.
Regards.
Diego
Just for clarification - Whether you have license for both ECC and Ariba ?
Just for ARIBA-P2P.
