Variable number of KPI's in a column chart
Hi Community,
is there a way to build a “dynamic” column chart with 1 dimension but several, variable KPI’s?
The problem is, once I include all possible KPIs the bars won’t be displayed anymore. In most cases only a certain number of those KPIs is necessary.
For example:
CASE A: Dimension (matnr.1): KPI1 (2), KPI2 (0 or -), KPI3 (4)
CASE B: Dimension (matnr.2): KPI1 (0 or -), KPI2 (1), KPI3 (0 or -)
In Case A only the KPIs 1 and 3 should be displayed in the column chart.
In Case B same for KPI 2.
Is it possible to change the visibility of KPIs on the basis of the CASE (A or B)?
Maybe by using a parameter?
Thanks for your help!
Alex
