Use Variable as Column Header
Dears,
Is it possible to use a variable to as a column header?
In the example below , Variable Visualization_KRI_Main_title , contains the name of the selected KPI (i.e. “Ratio of XXX”) , we want to use this variable as a header.
Can you please advise?
Thanks!
Hi @cristian.garofalo,
thanks for reaching out to us! I have replicated the issue and for me it works fine.
To further investigate why it didn’t work for you, let me raise some question:
  • Did you define a variable for the title as well?
  • Did you consider that calling a variable is case sensitive?
Justin
