Use RANGE to fill dropdown items
Hi all,
I want to have a dropdown button with the values 0 to 12, which I can generate using
RANGE(0, 1, 12)
however when I run/use the dropdown button it does not show any items.
Is this supposed to work? (we’re running CPM 4.5)
Joos
Hi Joos,
I faced the same issue as you did, I forwarded this topic internally to check if this behaviour is intended.
I will get back to you as soon as I have an update.
Viana
