Transfer Analysis table data from Celonis to Python using CelonisConnector()
Hi All,
I am trying to connect the Python with Celonis and importing data from Celonis Analysis directly (not from datamodels).
I went through documentations of Python API but could not get any class or method to get data of Celonis analysis.
I read somewhere about CelonisConnector() but couldn’t get any PIP install link for that.
Please suggest any resource or any way to proceed further.
Pushpendra Sharma
Hi Pushpendra,
You need to get the component you want to export first (change the analysis ID, sheet_name and component_name accordingly):
a = Analysis(1)
sheet_name = "New App 7"
sheet = a.document.sheets.filter(lambda x: x.name == sheet_name).first()
component_name = "my component"
c = sheet.components.filter(lambda x: x.get("title") == component_name).first()
If you are using celonis_tools 1.0.0, you can directly call
df = c.get_data()
to get the dataframe for this component.
Hope that helps!
David
