Total Purchase Order Value (converted in EUR)
Hello Celonis community,
I’m struggling with the PO-Value (converted in EUR) for our PR to PO process.
I just found the "EKPO.NETWR_CONVERTED” on item-level.
Is there any existing datafield (EKKO) or could somebody help me with the statement on header-level (Key: Source-System and Document No)?
Your help is highly appreciated.
Thanks in advance and kind regards,
Christine
#3
Hi Christine,
in order to calculate the net order value on header level, you can use the PU function which sums up every item value to the header value:
PU_SUM(“EKKO”, "EKPO.NETWR_CONVERTED”)
Viana
#5
Hi Viana,
Thanks a lot for your reply.
Maybe I have to expend my question.
For our dashboards we want to cluster the PO value to certain value ranges. These we want to use e.g. in a filter or chart.
Variable 1 (PO_Total_Value):
PU_SUM(“EKKO”, “EKPO”.“NETWR_CONVERTED”)
Variable 2 (PO_Value_Range):
CASE WHEN VARIABLE(<%= PO_Total_Value %>) >= 0 AND VARIABLE(<%= PO_Total_Value %>) < 25000 THEN ‘0 - 25.000 EUR’
WHEN VARIABLE(<%= PO_Total_Value %>) >= 25000 AND VARIABLE(<%= PO_Total_Value %>) < 50000 THEN ‘25.000 - 50.000 EUR’
WHEN VARIABLE(<%= PO_Total_Value %>) >= 50000 AND VARIABLE(<%= PO_Total_Value %>) < 100000 THEN ‘50.000 - 100.000 EUR’
ELSE ‘> 100.000 EUR’
With just the NETWR_CONVERTED it works like this.
Kindly regards,
Christine
