TimeStamp Variance between manuel and automatic inputs
We noticed that in our SAP system the time stamp for everything that is automatically documented (change and entry times) differs from the manual entries.
We have already found that the system time is used for automatic entries and the time zone time is used for manual entries.
Has anyone here had a similar problem or has anyone an idea how we can handle the time zone cases?
System time is CET.
Thanks in advance
Hi Niklas,
you could convert the timestamps in the transformations based on the user type for each activity.
For every activity, you use the USTYP from USR02 table, so you could add a condition like
CASE WHEN USTYP = B THEN DATEADDFUNCTION()
ELSE TIMESTAMP END
(p.s.: USTYP B stands for automatic activities)
Viana
