Take minimum of two groups in Celonis front end
We are working on an issue where we would like to list the lowest order number activity within a certain case key, within a certain change number.
E.g. picture attached might clarify the situation a bit more.Finding the correct root cause
We want to do this in the front-end (the dashboards) of Celonis.
Hi Rick, welcome to our community! I have moved your post to a more fitting category since we are just building our student area. Is there a way you can replace the sorting numbers by letters? That would solve the issue. You could also try doing that after uploading the file through SQL in the Celonis IBC as a data job.
Josua
Hi Rick,
have you tried to do this by using the multiple sorting configuration in the table settings?
Viana
