Sum of Distinct values
Hi Team,
I am working on pulling sum of values from a particular table column in Celonis using PQL. I want the sum of distinct values of the table column. However, when I do SUM(DISTINCT Table.Column) it is giving me sum of all the values in the column and not the unique ones.
Is there any way in which I can find the sum of unique values of a table column?
Thanks in advance
Regards,
Soham Potdar
Hi Soham,
have you tried using the following statement?
SUM (COUNT ( DISTINCT table.column ))
this formula should first count the distinct values of a column and then sum all of them without considering the duplicates.
Regards,
Carlo Alberto
