SAP data negative but positive in Celonis
I would like to understand why when I extract the movement type for a cancellation of reception, the result appear in positif in Celonis ?
SAP : image
CELONIS : image
I verified that are the same ligne (mvt type 102, same PO, etc)
Thanks in advance.
Hi Audrey,
in order to answer your question more specifically, I would ask you to specify if you’re using Celonis4 On-prem or IBC?
Thanks and best regards,
Viana
We are using the version 4.3. - Release not in IBC.
Audrey
