Resize buttons and buttons' text
frontend
Hi Community :slight_smile:
I would like to use a button as a table title so that people can click on and see more discussion.
My question is, is there a way to increase text size or button size vertically?
Thanks :+1:
#3
Hello wjiraru,
It is unfortunately currently not possible to change the font size in Button titles.
It is possible to change the font the title is written in and some font sizes are larger than others so maybe that is an option for you.
Another possible work around would be to put a โ€œText Componentโ€ on top of part of the Button. As in Text Components it is possible to increase text size. If the viewer then clicks on the uncovered part of the button it can still open the description.
I hope this helps.
Henry
Picture of the Text field solution:
