Remapping work days
I have a problem that was addressed in another topic however, I have tried the solution and it did not work.
Basically i would like to sum up the euro value of invoices that have been completed within 2 working days. We dont have the calendar table in our data model so using the working day formula does not work and therefor I have tried the below work around that has been suggested. However, am getting an error.
Can you please let me know where my error is?
SUM( CASE WHEN DAYS_BETWEEN( REMAP_TIMESTAMP (ROUND_DAY(“BKPF”.“BLDAT”, MONDAY 08:00-17:00 TUESDAY 08:00-17:00 WEDNESDAY 08:00-17:00 THURSDAY 08:00-17:00 FRIDAY 08:00-17:00 ),REMAP_TIMESTAMP (ROUND_DAY(“BSEG”.“AUGCP”, MONDAY 08:00-17:00 TUESDAY 08:00-17:00 WEDNESDAY 08:00-17:00 THURSDAY 08:00-17:00 FRIDAY 08:00-17:00)) <=2.0 THEN “BSEG”.“EURO”
ELSE NULL
END)
Thanks for your help!
Anna
Hello Anna,
REMAP_TIMESTAMPS returns an integer, so you cannot use it inside DAYS_BETWEEN (which only works on timestamps).
REMAP_TIMESTAMPS returns the number of time units you specify (DAYS, MINUTES, …) since 1.1.1970 as an int. So by subtracting two REMAP_TIMESTAMPS results, you get the difference between the corresponding timestamps in the specified time unit.
So your query would look like this:
SUM(
CASE WHEN
REMAP_TIMESTAMPS ( “BSEG”.“AUGCP”, DAYS, MONDAY 08:00-17:00 TUESDAY 08:00-17:00 WEDNESDAY 08:00-17:00 THURSDAY 08:00-17:00 FRIDAY 08:00-17:00)
REMAP_TIMESTAMPS ( “BKPF”.“BLDAT”, DAYS, MONDAY 08:00-17:00 TUESDAY 08:00-17:00 WEDNESDAY 08:00-17:00 THURSDAY 08:00-17:00 FRIDAY 08:00-17:00)
 < 2 THEN “BSEG”.“EURO”
ELSE NULL
END)
You can find an example how to use REMAP_TIMESTAMPS to calculate a time difference in the documentation of REMAP_TIMESTAMPS.
David
