R Server Connection Issue
I would like to establish an R connection working in a Single User Celonis version on a local device, but unfortunately it doesn’t work. I followed the instructions in your installation guide, and according to that document everything should be fine. I tried to adjusted a custom properties document, and also restarted Celonis, but still I get the error message that it cannot interact with the R server.
I hope you can help me out with this issue…
#2
Hey,
did you make sure that your Microsoft Open R interpreter is on the same R version as your other applications?
Maybe that helps already…
Kind regards
Linda
#3
Good hint!! Actually that was the problem :smiley:
Works like a charm now!
Thank you so much
