Procurement Process - What is the definition of change rate and rework rate?
Hi there, what is the exact calcuation of Change rate and rework rate in the process Cockpit? Thanks, Daniela
#3
Hi Daniela,
Change KPI
All Changes of Original Process Document Information. Updates in Status or Meta Information are no Changes.
Impact: Changes can be necessary, but should be minimized in the process.
Business Case: Minimize Changes. Calculation by FTE Reduction.
PQL Example:
100.0*AVG(
CASE WHEN PU_COUNT(
        "purchase_order_lines","_CEL_COUPA_P2P_ACTIVITIES"."ACTIVITY_<%= language %>",
        "_CEL_COUPA_P2P_ACTIVITIES"."CHANGED_FIELD" IN (<%=ChangedFields%>)
         ) > 0
THEN
    1.0
ELSE
    0.0
END)
Rework KPI
All Activities in a process which are executed more than once.
Impact: All Rework should be avoided in general
Business Case: Duration for each activity done beyond the first.
Hint: If a change is executed more than once it also counts as rework.
PQL Example
100.0*AVG(
CASE WHEN PU_COUNT("EKPO","_CEL_P2P_ACTIVITIES"."ACTIVITY_<%= language %>" ) - PU_COUNT_DISTINCT("EKPO","_CEL_P2P_ACTIVITIES"."ACTIVITY_<%= language %>" ) > 0
    THEN
        1.0
    ELSE
        0.0
Hugo
#4
Great Thanks :smile:
