Process explorer KPI - use a field from case table
I have two tables in the data model - an activity and case table.
I wanted to show the sum of ‘payment amount’ on each activity of process explorer, so I can see how much value those activities represent. I have used following code but it’s not giving me the correct numbers.
SUM(“CASE Table”.“PAYMENT AMOUNT (GBP)”)
Please can you help?
Thanks,
AJ
Hi AJ,
I have no idea whether this works but did/could you also try to use a Pull Up function, like PU_SUM(case table, case table . payment amount)?
Thanks for the response joosbuijs.
I tried it and it doesn’t seem to work either.
