Dear all,
I have a few different questions about the Process Data Model. I think there have been a few CELONIS adjustments in the past.
Even though the relationship between activity and case table is correct (Process will be shown in the process explorer in the correct way) the display 1:N is mirrored (pic #1).
In the past it was possible to declare/identify the case table with a ©. I can’t find this option any more in the drop down option (pic #2).
In general we need to insert two sources (different systems) in the same process analysis.
They are running in parallel and are differentiated by additional information in the case (pic #3). The data is written into the case table. Difference than usual (normal create case table syntax), we use the SQL Vertica “insert into” syntax like we used in the activity table. We have to match two different systems with different data sources. In my opinion it will work fine, but I am not really sure that we can use it that way. -
Although I only created the two tables (case and activity) in the process model a third table was created automatically in the analysis (activities_cases / pic #4). I can’t see this table in the process data model!
If you have any information for me I would be very grateful. thx
