Process Automation: Optional Values
Hi community,
I am currently creating a process automation that takes values that are filled in a signal action and writes them to a table. One of the attributes should be optional because it’s just “additional remarks”. How can I do this?
Thanks a lot.
Hey,
If I get this correctly, you could just create a KPI under Saved Formulas.
Then you could add a parameter and change the type to String for example.
Then you are able to pass the parameter later on, when you want to use the KPI.
Best regards
