Process Automation Challenge Summer 2020
On July 14, we announced we’re running a process automation challenge across our community. If you haven’t had a chance, watch the webinar in which we announce the challenge on-demand and take the training on the Celonis Academy for step-by-step instructions on how to set up your own Skills.
The webinar introduced the capabilities and benefits of process automation within Celonis and demonstrated a customer-inspired use case for intelligently handling urgent customer orders.
Your challenge is to pick a problem from YOUR day job and solve it using Celonis!
Is there something you find yourself doing over and over that you wish you could automate? Do you ever miss an urgent or important item because it’s lower on your to-do list? Do you wish you could more easily spot duplicates or predict when things will be late?
These are all great uses for Celonis!
How to enter the challenge:
  1. Create your solution in your Celonis environment
  2. Create a post on this thread describing the challenge that you were experiencing. What was your previous way of working? Why was it important for you to solve?
  3. Explain how you solved the challenge with Celonis. What insights did you gain? Which systems did you take action in? Who did you send tasks and alerts to? If possible, we’d love to see screenshots or video of your solution in action.
We will review the posts and select a winner on August 17, 2020. The winner will be the participant who is addressing the most impactful problem with the most creative solution in Celonis.
