Pro tip: Share your analysis via "Public Link"
Celonis offers you a lot of features to share your success stories or achievements with other people. One of them is the so-called functionality “Public link” which allows you to share the published version of your analysis with this link.
  • First, navigate to Process Analytics
  • Click the dropdown menu of the analysis you want to share
  • Then public link
  • Click Enable public link
  • Click Copy to Clipboard
  • Click Save
  • Every person who has this link will be able to use (not edit) your analysis.
For example, this is my analysis that I share with you via this link:
https://snap-er-ndrio-gmail-com.eu-1.celonis.cloud/process-mining/public/df45b38a-46d2-4b4c-9ec2-4fc2293c15a8/#/frontend/documents/df45b38a-46d2-4b4c-9ec2-4fc2293c15a8/view
Is there any way to share an analysis path, so that the user gets redirected to a particular folder and find the analysis ?
Regards,
RJ
Thank you for asking. I think you can share any link as long as they have access rights to it.
Regards,
Erin
