Pricing in O2C / SAP SD / KOMV - pulling a structure from SAP to IBC possible?
Hi everyone,
I am fairly new to Celonis.
We have the O2C process loaded (SAP ECC), with, as I understand, more or less standard activities defined.
Now, one of the business stakeholders asked me if we can add pricing data. In particular he would like to have the data from “Conditions” tab of the “Display item details”: Active / Condition type / amount and so on.
As far as I can see the data there is coming from KOMV, which is a so called “structure”.
Do I understand correctly that loading such a structure directly to IBC is not possible? Or is there a way?
Thanks a lot
Masha
Hi Masha,
structures can’t be directly extracted - but the data written in structures is most probably stored in some actual field and table name. You would first need to find out (with help of your SAP team) in which table and field the information is stored.
Viana
hi Viana,
thank you very much for prompt response! Are there any plans to make this possible?
Masha
Hi Masha,
I think it’s not possible to extract structures because they are not saved in the required table format in the SAP System. However, most information displayed in structures is saved somewhere in a proper table format.
Viana
