I’m trying to calcul the difference between to column in the same OLAP table. I used this formula :
{TMP_CDHDR_CDPOS.VALUE_OLD}-{TMP_CDHDR_CDPOS.VALUE_NEW}
but the system alway run… he never give me a results why ?
If it’s not giving an error it might just take a wile?
Might help to aggregate or at least filter the output/component.
I’m also wondering about the ‘{’ and ‘}’ notation, fur us (CPM 4.5 on premise) we need to use ’ around table and column names.
Hi, when i’m using the title of the column without the ‘{’ and ‘}’ I receive an error.
Thanks for the help.
You need to use the STR_TO_INT() function to convert the values to Integers rather than String values. You cannot do mathematical calculations on strings.
When I put this formule, i’ve no result, the column become empty. Why ?
STR_TO_INT(“TMP_CDHDR_CDPOS”.“VALUE_OLD”).
Hi Audrey,
the STR_TO_INT function returns null, if the input is not a number.
My solution for that would also to cast the numbers which are loaded as strings with the STR_TO_INT function so that they can substracted.
Viana
