Olap Tables and layers
I’m trying to use 2 olap tables (one in front of the other) and a button dropdown with two variables and I want that one olap table come to the front layer when I select one of the variables in the dropdown button and when I select the other variable in the dropdown button the other table comes to the front layer again. Is this possible?
Thanks in advance
Hi @Hugo,
Welcome to our community!
Unfortunately, you can not trigger the Layer Order using a button dropdown. However, you could try to use variables for your Dimensions/KPIs. Then you could switch between variables using the button dropdown. Your OLAP table will then adjust accordingly.
If you need a hint how to do that, let us know!
Justin
