Need HELP: KPI for Touchless or Manual Intervention or Unknown
Hello
I am trying to create a KPI called “PO Touch Indicator” that will allow me to have a Value of ‘touchless’, ‘manual intervention’, or ‘unknown’ based on the activites and User Type per PO.
When AT LEAST one UserType = ‘-’ then ‘unknown’
When ALL UserType = ‘B’ then Touchless
When AT LEAST one UserType = ‘A’ and rest are ‘B’ or all are ‘A’ then Manual intervention
Ex 1:
PO: 12344232 // PO ITEM: 01 // Activity: 1 // UserType: A // KPI "PO Touch Indicator: ‘unknown’
PO: 12344232 // PO ITEM: 01 // Activity: 2 // UserType: - // KPI "PO Touch Indicator: ‘unknown’
PO: 12344232 // PO ITEM: 01 // Activity: 3 // UserType: B // KPI "PO Touch Indicator: ‘unknown’
Ex 2:
PO: 12344232 // PO ITEM: 01 // Activity: 1 // UserType: B // KPI "PO Touch Indicator: ‘touchless’
PO: 12344232 // PO ITEM: 01 // Activity: 2 // UserType: B // KPI "PO Touch Indicator: ‘touchless’
PO: 12344232 // PO ITEM: 01 // Activity: 3 // UserType: B // KPI "PO Touch Indicator: ‘touchless’
Ex 3:
PO: 12344232 // PO ITEM: 01 // Activity: 1 // UserType: A // KPI "PO Touch Indicator: ‘manual intervention’
PO: 12344232 // PO ITEM: 01 // Activity: 2 // UserType: A // KPI "PO Touch Indicator: ‘manual intervention’
PO: 12344232 // PO ITEM: 01 // Activity: 3 // UserType: B // KPI "PO Touch Indicator: '‘manual intervention’
Hello Neel,
This is best solved by a Case When Statement. I think the shortest way would be to Count the Distinct User Types on Case Level. If it’s 1 User Type and that User is B then its touchless, if the Count of ‘-’ Users is greater than 0 its unknown and all the rest would be manual intervention.
Benedict
Hi Bene
Thank you for your advise
can you please give me an example this CASE WHEN statement ? I’m not too sure how to write this formula
thank you !
Hey Neel,
In order to calculate something from the activity table on case level, one has to use PU_Functions. Please see our PQL-Reference for more Information on them.
Something like this should work:
CASE
WHEN PU_COUNT_DISTINCT(“YourCaseTable”, “YourActivityTable”.“USERTYPE”) = 1 AND PU_LAST(“YourCaseTable”, “YourActivityTable”.“USERTYPE”) = ‘B’
THEN ‘Touchless’
WHEN PU_COUNT(“YourCaseTable”, “YourActivityTable”.“USERTYPE”, “YourActivityTable”.“USERTYPE” = ‘-’) > 0
THEN ‘Unknown’
ELSE ‘Manual Intervention’
Bene
