Mult two tables
I tried to build an OLAP table with les champs suivants :
CHANGED_FROM : “_CEL_P2P_ACTIVITIES”.“CHANGED_FROM”
CHANGER_TO : “_CEL_P2P_ACTIVITIES”.“CHANGED_TO”
OverDelivery: “EKPO”.“UNTTO”
UnderDelivery: “EKPO”.“UEBTO”
I would like to create an column with
CHANGED_FROM * OverDelivery
But I received an error message. How could I do this multiplication between those tables ?
Thanks in advance.
Hi Audrey,
thank you for your question!
The error message appears as you are multiplying a string input with a float which is not possible.
In the standard P2P datamodel you should have the column CHANGED_FROM also in float format. This Column is called:
“_CEL_P2P_ACTIVITIES”.“CHANGED_FROM_FLOAT”
If you don’t have this column you need to set it up by casting the respective input column as a float int the Event Collection.
Hope this helps!
Celonis Data Science Team
