Movement of Analysis from one Workspace to another
Hello Team,
Can you please help how to move an analysis from one workspace to another with all the variables, filters and other stored details.
Hi Pritam,
In order to move analysis to another workspace you need to select “Move to” in the right corner of the respective analysis button (see Screenshot below). Then you need to select the team in the menu that pops up and the workspace you want the analysis to move to. After this a preview of the target workspace will be visible and you can click “Create new” and tick the box “delete from source team” on the bottom right as well to move the analysis to the new workspace and delete in the source workspace. If you only want to copy don’t tick the box respectively.
Hopefully that’ll solve your issue!
2
3 (2)
4
Thank you :slight_smile:
