Monitor Data Integration Executions
Hello all,
one of my daily tasks is to verify the data extracted from different source systems.
I verify manually different Executions in the Data Integration Tool. Do you know if it is possible to have a global point of view for all those different loads?
Thanks in advance for your time.
unfortunately, there is no global point of view for all executions. In the overview you would have the last status of each job.
Viana
