ML Workbench Data Pull
Hi Team,
In the ML workbench, we are trying to pull data of a component from a particular analysis
The code that we are using is not able to pull data from some particular analysis. However, if we use the same code to pull the data from a different analysis belonging to the same workspace we are able to pull the data.
Are there any Analysis settings that we need to look into for the data pull that might be causing this error.
We are getting the following error while pulling the data from the analysis.
Hi Soham_Potdar,
I tried to reproduce your error, but for me it worked as expected. I gave the API key the following permissions on workspace level:
  • Use all analyses
  • Edit all analyses
  • Edit workspace
Probably this would also work on analysis level. I had the same problem with a data pool back-up. Apperently you have to provide edit settings, only 'use … ’ (so read-only) is not enough. Hopefully this solves your problem.
Bests,
Hi Jan-peter,
Apologies for a delayed reply.
Thank you for the response.
After doing some debugging on the issue we are observing that if the conformance sheet is present in the particular analysis we are facing this issue. For the other analysis we are not facing any issue in the data pull.
Currently for the particular data pull we are copying the conformance query from the analysis and using it in another analysis due to the issue faced in data pull however we want to use the same analysis for the data pull as well.
Please let us know any way in which we can solve this issue.
Thanks in Advance
Soham Potdar
