Measure Booking Process by Order Level
I need to measure the number of orders within the booking process: anything between Create Quotation and Create Sales Order Item. For background, the # of Sales Orders using COUNT_TABLE("VBAK") is 200k.
Using either of the below formulas continues to give me 200k Sales Orders. I have also attempted it with/without many different component filters:
COUNT(DISTINCT CASE WHEN
"_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" IN ('Create Quotation','Create Sales Order Item')
THEN "VBAK"."MANDT" || "VBAK"."VBELN" ELSE NULL END)
or
COUNT (DISTINCT CASE
WHEN (PU_COUNT("VBAK","_CEL_O2C_ACTIVITIES"."USER_TYPE","_CEL_O2C_ACTIVITIES"."USER_TYPE" LIKE '%'
				AND "_CEL_O2C_ACTIVITIES"."ACTIVITY_EN" IN ('Create Quotation','Create Sales Order Item'))
				= PU_COUNT("VBAK","_CEL_O2C_ACTIVITIES"."USER_TYPE", "_CEL_O2C_ACTIVITIES"."ACTIVITY_EN"
                    IN ('Create Quotation','Create Sales Order Item')))
			    ELSE NULL
You guys have been a tremendous help in the past, would love to see what I am missing or any other suggestions.
I’m not sure if I understood your question correctly. So do you want to calculate the number of cases that have gone through Create Quotation and Create Sales Order Item afterwards?
Could you clarify this a bit?
Thanks and BR
David
@d.becher,
Not necessarily directly afterwards.
Another way of stating it would be the crop selection: image
For example say I was doing throughput time bucketing for the booking process, the PQL would be:
CASE
     WHEN DATEDIFF(DD,
PU_MIN(“VBAK“, “_CEL_O2C_ACTIVITIES“.”EVENTTIME”, “_CEL_O2C_ACTIVITIES“.”ACTIVITY_EN” = ‘Create Quotation’)
, PU_MAX(“VBAK“, “_CEL_O2C_ACTIVITIES“.”EVENTTIME”, “_CEL_O2C_ACTIVITIES“.”ACTIVITY_EN” = ‘Create Sales Order Item’)
) <= 5
                        THEN ‘<= 5’
Perhaps we can apply something similar to the crop function onto the analysis sheet filter as a whole?
In order to calculate the number of cases that have gone through Create Quotation and eventually through Create Sales Order Item, you can use PROCESS EQUALS:
COUNT( CASE WHEN PROCESS EQUALS 'Create Quotation' TO ANY TO
'Create Sales Order Item' THEN 1 ELSE NULL END )
This also respects the cases where the two activities do not follow each other directly, but there can be other activities in between.
David
