Link in notification banner
I created a banner in system settings -> notifications. There is only a text field, but I like to insert a link. When the banner is active the link is not selectable and any text in the banner can not be highlighted for copy and paste. HTML does not work in the text field.
Did someone find a workaround for this issue? Would be much appreciated. Thanks.
#3
Hello Franziska,
you could try the following:
Use https://tiny.cc/ to shorten your link and customize it to use something that can be easily remembered.
In the following example I used the URL https://example.com to generate https://tiny.cc/thisNotification
You can, of course, use much longer URLs for this.
Your colleagues can then type the URL into the browser directly.
When you access https://tiny.cc/thisNotification you will get redirected to https://example.com .
See also the screenshot
Hope this helps,
Nicolas
#4
Hello Nicolas,
Yes, that is a pliable workaround.
Thank you!
Franziska
